Difficulty pulling gas tank on 1986 Supra Comp TS6m
3 years ago I bought my 1986 Supra for wakeboarding on the lake where I live. It ran well the first year, but ever since, it stalls when idling or after running fast. Last year the morning after putting it in I found it sunk at my dock. Turned out the boot on the drive shaft was off the springs, probably displaced by the guy who winterized it. Since then it has performed even worse despite my pumping the tank at the gas filter five times and several bottles of Seafoam, etc. Finally, we rebuilt the Holley and the power valve was defective. Now it's running better, but still reluctant at start up and unpredictable other times. The mechanic says the problem is water: pull the gas tank and clean it dry with rags, then blow the lines and change the filters again. But I can't get the tank to move after taking off the 2 retaining brackets. I saw an old post suggesting to loosen the tank's seat under the aft locker where it might be stuck with accumulated gunk using a crowbar. But I'm not sure how much slack the filler tube, vent and fuel line have, and am afraid I may break their connections if I just try to slide it out. It is in so tight I can't see those fittings and hoses and no access from above. Anyone been into these tanks before?
