Can bent skegs cause bad list at speed?
Back at the pond today to make sure my exhaust re-seal job worked. This thing is a handful when it is running over 35mph. Not to mention I can't seem to get more than 40mph but thats not a big issue. I can see that 2 of my 3 skegs are bent so that if you are looking at them from the rear the bottom of the skeg is maybe 1/2 to 1 inch off center to the strarboard side. They may have a little twist as well. Might this cause handling issues at speed? The biggest issue is that the boat doesn't ride no where near level once on plane. I am 6'2" tall and I cannot see the water out of the port side windshield when on plane. Also it is VERY darty if I try to run flat out at about 40mph. Any one ever experience this? I have some play in the steering so that my be contributing to the high speed issues but I would really like to get it to ride a little more flat once on plane.
I would think a hydraulic system is not even worth it let alone feasible. I'd look at first fixing what is there. Your adjustable wake plate needs to be flush or just a 1/4 inch higher than the hull otherwise at high speed it wants to lift the stern and bury the nose which can make for a very unstable driving boat.
