1988 Supra Saltaire - thru hull exhaust replacement
Looking for some helpful advice on replacing the thru hull exhaust plastic flange. I have the ski tray out, and I can see the exhaust flange. Can I just replace the flange or do I need to pull the gas tank. The boat is sitting on the boat lift. Memorial day was an adventure, the raw water pump went and the boat overheated. Then the flange deformed causing a big leak.
Engine is ok, raw water pump replaced and its running good! Thank goodness. We need to get this fixed and I'm rocking again.
Thanks Home of Leinenkugel's!
