Supra 2009 Wishlist
Hi,
Here is my wishlist of supra options for the 2009 models:
+ Optional black swifel boardracks on all models
+ Optional black speakers and lightbaron all models .
+ Optional black wakeboard tower on all models.
+ Optional extra radio remote in the boat (ex. at the back near the backseats or in the bow).
+ Skip the transom remote.
+ The ski lockers left and right in the back coated with water resistant material and a drain(because i put in my wet ski's and suites in there).
+ Fuel consumption meter (flowmeter that counts the amount of gallons/litres each hour).
+ Horn button in the centre of the steeringwheel.
+ Better headunit setup (these Kenwoods units are not that new).
+ Dasboard Switch where you can disable the speakers in the boat and only operate the towerspeakers.
This is my list that would make my new Supra complete.
I realy hope that SC reads this forum and think about the comments we ''customers" make.
If they know how to make there products better, they are worth the $$$$.
my list
Yes to all on the list then add
1- put the Sunsport bow seating on the launch
2-let the rear steps be an option on the Sunsport
3-world package for the Sunsport
4- move batteries out of the storage compartment
And move the cross braces in the floor plates so they will not rub a hole in the fuel tank. Or at least line them up so they fit in the grooves when the boat is being put together.
2009 Supra Wish List
Greetings Supra Leadership:
I agree with the previous items mentioned by other Supra enthusiasts. Please consider the following enhancements to an already legendary product:
+ Lower the height of the Helm Dash and Port Side Glove Box to improve visibility
+ Add Drains to Port and Starboard Storage/Ballast compartments
+ Lower the breaking point on your folding towers to allow easier storage in tighter fitting garages
+ Add casters to Trailer Prop Guards
+ Offer Playpen configuration on the 20SSV similar to the 21V
+ Move Bow cupholders on 20SSV from under the bow filler cushion to a more accessible place.
+ Improve lighting in Storage compartments
+ Offer Gravity games package on all Launch Series models.
Looking forward to seeing the 2009 line-up. Thanks for listening.
Best regards,
MTT
A few more additions
A bilge pump at the lowest point in the hull (maybe around the V-drive) or @ front ballast.
A longer hose from the oil pan drain line ( that will reach through the plug hole)
Fold up arm rest on the drivers seat.
Storage shelf or pockets @ drivers feet right side in front of cup holder
Add 12" to the tower bimini so it will extend beyond the windshield (Rain drips back in the cockpit)
Just my input for what it's worth!:):)
+ Tilt the helm radio control so that you can see it without crouching down while driving.
+ Insert so that you can make the cooler smaller if all the space is not needed. (22 SSV)
+ Rail to hang gloves on that doesn't block access to cup holders.
Echo: Tilting Helm Stereo Remote
Dual Bilge pumps, 2nd T-plug, or similar solution to water build up in front ballast compartment
Removeable carpet throughout the boat or at least no carpet and instead textured fiberglass in rear ballast/storage compartments
I would like to add:
-Make sure the accent stripe directly under the rub rail is at least 3.25" in height in front of the bilge and horn vent so that registration numbers will fit in that space.
SC is reading this topic. I send the link to product development and the replied that they liked the tread.
Let me start with... I love my Supra so far! Of those that were mentioned, only a few ideas resonated with me:
My list (only the last two offer anything new):
1) tilt adjustment on the drivers' stereo remote (you can't see it in the sun)
2) Thicker hull-stripe below the rub-rail for registration decals (at least 3.25" for 3" decals)
3) lower dash 1" (or raise drivers' seat 1") -- I'm short at 5'8" and have to sit upright to see
4) Come up with a draining system under the ballast bags in the rear compartments, like a raised mat that allows air underneath (hey, I just realized I can do that myself...!), or line-x'd floors back there...but no sacks directly on carpet. Wet carpet plus wet environment (Seattle) makes for nasty smells and surface mold...
5) Get rid of the docking lights on the 22, they aren't necessary and are too close to the waterline.
That's a pretty short list. Nice work, Supra!! :)
