I am not with my boat right now but in the process of buyimg a new engine, what is the propeller rotation of my 1991 supra sunsport. 351 windsor. Pcm powerslot 1.23x1 transmission?
I want to make sure as i search for a different 351
Edge
Edge
1:23 to 1 pcm transmission is a right hand rotation of the prop
Hey Edge,
Maybe this can help. Your firing order should be on the engine tag.
http://www.planetnautique.com/vb3/sh...0-firing-order
Ok, you have a PCM tansmission with a RH rotation output, but it has a LH rotation input. Your engine is a LH rotation viewed from the flywheel.
Al
So if its right hand rotation of the prop it would be left hand or a standard rotation engine, on a 1.23x1 pcm
my understanding is that the rotation of the 1:23 to 1 is the reverse of the engine rotation.
If Engine rotation is left then tranny is right
If Engine rotation is right then tranny is left.
Any doubts check with ski dim - can alway answer your questions.
