SUPRA SA, Piggyback Ballast and Autowake
Hi, I'm considering a 2021 Supra SA. I'm interested in maxing out the ballast, specifically by adding a single u-shaped bag under the front bow seats, with a pair of bags equaling that front weight in the two rear lockers.for example, if that front bag is 600 pounds, I'd install a 300 pound bag in each rear locker to ensure equal piggyback weight throughout the boat.
In my research I understand there is a draft sensor that may prevent putting too much weight in the boat, along with ballast pumps that stop when capacity has reached 100%. With this said, I'm looking to better understand the ballast system so I can accomplish my goal.
1. How are ballast levels measured? Do the ballast pumps have timers that can be adjusted so I can reach 100% once the stock and piggyback bags have reached max capacity?
2. Regarding the draft sensor, is there a certain amount of weight in the boat that is reached in order for the draft sensor to max out? Can this setting be adjusted?
3. What does the plumbing and pump configuration look like? Are these reversible pumps to fill and drain? Are there vent hoses?
Any suggestions would be greatly appreciated. This is an impressive boat and I'm looking forward to massive surf wakes. Thank you.
Try to PM goose
Let us all know what you find, ordering a 21SA tomorrow.
I don’t think 500# of lead will hurt your cruising mpg too much. Unless you do a lot of 35mph cruising.
One of the main reasons I moved from an 18SA to a 21SA was it was all subfloor ballast. Lead just takes us such little space compared to a bag.
I don’t want a bow bag because I am so looking forward to putting the box anchor and 150 foot of rope under the hinged bow seats.
