Okay last night I installed the pcm Prestolite Electronic ignition and it says for me to bypass the ballast resistor,
From what I gather this is the 2 terminal sensor in the back of the motor by the starter solinod on these older supra's,
What I did is just unbolt the one side and bolted them together on the right side! Should this be fine or should I unbolt it all together and just butt connector it?
