Belt information needed
Replacing the belts on my '86 PCM 351. Belts from skidim are $18 and change plus $12 shipping so, call it $30 for new belts. Trying to find them local and all the part numbers carry over to V-belts with teeth on them which I cannot use. What are you guys using for belts or what are the dimensions of the belt so I can try and save some money by finding them local and not having to pay shipping?
Take them with you to napa. They should have a tool to find the length
Well, that would work in theory however, someone in the household went on a cleaning spree and tossed them for me.
Just take the item numbers from skidim and cross reference them with Napa and they can hook you up... If I remember right skidim actually had the other reference numbers on their site that Napa could find
Take a 3/8 rope and guide it around the pulleys then measure the length. That should get you close . Best to do it at the parts store it may take a few belts to get the right one.
This should be the information you need:
PCM RP066001/8 Belts Ford 302/351
Product Description:
Alternator and Raw Water Pump Belt Set - Fits PCM Ford 302/351, HO, GT40, Pro Boss
Product Specs:
R066001 - Alternator Belt is 3/8" wide, 39-1/2" overall length, 5/16" height of V NAPA P/N: 25 7444
R066008 - Raw Water Pump Belt is 3/8" wide, 45" overall length, 5/16" height of V. NAPA P/N: XL 25 7448
SOURCE: https://www.bakesonline.com/detail.aspx?ID=2196
edited for NAPA part numbers... I believe those are correct.
