water in engine compartment and bilge issues
Hi all,
We have a 2008 supra launch 20 ssv
First post. Did some searching and cannot find any info. The ballast tank valve appears to leak and allowed water (fresh) into the engine compartment. The bilge failed to turn on automatically. The light is on for the bilge on the off position but wont turn on. The other electrical all works and we used the ballast tanks to drain the water in the boat. I havent tried to start the boat yet. The alternator was def under some water but thinking it may still run when we restart.
Is there a fuse for the bilge? Would one of the breakers have gone in this situation? Anyone know how to remove the bilge or have some online resource to figure this out? The owners manual is vague on this subject.
Any thoughts or direction would be helpful
Rob
You will not find detailed diagrams available to the public on how to repair SC boat systems. Your dealer have the online pics and part numbers.
Per the bilge, if you know how to use a multi meter, check to see if you are getting power at the Atwood pump - when you have the switch on.
If you have power at the pump, you probably need to replace the pump.
Or there might be something stuck in the pump (debris). If you take it out of the boat, you can try to take it apart.
Easy job to replace. Turn the power off. Cut 2 wires. Some pumps have 2 parts. There is a plastic piece that holds the pump to the bottom of the boat. Then the pump snaps into that plastic holder. Use marine butt-connectors and some heat-shrink to seal it all up
