Anyone have pics on how the 1100lbs bag fits in rear locker of 2009ssv launch?
I have a 21V. 09 and it fits great. Takes 10 mins to fill
Pics? I was told the 1100 might not fit and could do damage to the locker. I bought the 750 and now have buyers remorse :(
you have to reinforce the bottom between the hinges, and make sure your hinge screws are tight or better yet thru bolt them, will take a pick this weekend.....its a simple bracket add
i also have the 750 bags and am regretting it now
Yes indeed.
Happened to me.
Bag filled, kinked the overflow line, cracked the fiberglass from the inside like an exploding egg. It resulted in $500 of fiberglass repair, not to mention the psychological damage.
If you keep a "close" eye on it, you can use it, but you won't get the 1100 full on a '09 21v. Maybe you'll get 900-950 lbs - Instead of having buyer's remorse, I'd advise to keep the 750 bag and put the stock 400 bag on the seat. You'll get more weight than the theoretical 1100 bag.
but if you do it, I agree with the need to reinforce the engine panel. I did that with u-channel on the engine compartment side of the panel and through bolts.
I got the 1100lbs bag last week and i put the 750lbs bag up top if just 3 of us. Makes huge wake thinking of putting 400lb bag up front to help lenghten wave.
I measured my locker and got 36L 24w 20h... cant figure out how you guys get the bag to fit either??
Specifications
Size: 50L" x 24W" x 24H"
Capacity: 1,100lbs.
