Have 2007 22ssv, ran boat 4+ hrs and all digital and manual gauges quit. The main
screen flashes- ENG ECU NO DATA Over 25 Seconds- boat runs fine. Any ideas or anyone else have this happen? Days like this make me miss my 90 sunsport!
I would check your wiring harness at engine and connections under dash. If your engine is running fine , the data coming from the engine ecm is not getting to your boats ecu under the helm. could be a lost ground. check your manual and all fuses and breakers
Thanks, will start crawling around lookin for the problem, w/a cold one.
@Brysteele - i just had this happen this past weekend trying to pass two boats surfing when their two waves merged and created a monster, my boat had a direct hit. The hull was fine, nothing damaged but the error code flashed on the dashboard. Did you correct your issue - was it at the engine or under the dash?
Thanks for the info - JY
