anybody tin 1/0 cable after stripping it, so it goes into a distribution block easily?
How'd you do it?
How'd you do it?
Normally no, but if you do, you'll need a torch. Soldering iron won't quite do it.
thanks.
Already got it done, and yes - a torch was necessary! I used one meant for copper plumbing.
I then had to grind the solder smooth to get it into the distribution box.
Fits perfectly in the socket and the set screw holds much better on a solid mass compared to the 5000 strands of a 1/0 cable.
