89 supra conbrio. 351w tuneup
		Trying to perform a tuneup on my 351w pcm and would like to know if there is a manual i can look at to find the basics.  I need to know gap distance on spark plugs and which distro caps i can order online.   I have sooo many other questions but i will start here.   My conbrio is open hull and my engine has the 3.5 exhaust.  I am curious to know if these engines have impellars or not.
Any and all tips, advice and comments are welcomed.   Id also like to know what carb is preferred.  Currently have a holley 4bb and want to change it out.    I will be searching the forums for threads that i hope already exist.  Pics coming soon!
		Raw water impeller...yes
As for the spark plug gap and timing, check your port side valve cover.
		Thanks for the posts gents!   Reading the manual for some general info now.
I noticed it calls for 2 guage wiring for 6ft+ wiring lengths.    I had 2 guage originally and replaced it with 4 guage high performance wiring (normaly used for audio setups).   I was wondering if this is causing my boat not to start.   Besides the throttle return spring and using a deep cycle battery over the cranking battery this is the only thing i have changed in the setup.  I still have my 2 guage so i am going to hook it back up and see if my boat starts.
