Impeller Installation Question
Just got done swapping the impeller on my 21v and had a slight concern as to the seating of the impeller within the housing. Seemed like the one I replaced was recessed slightly in the housing before I removed it. However, the one I put in came all the way to the edge of the housing and maybe even hung over a hair. The cover still went on, just not sure if it was actually seated all the way in. I moved it around pretty good until it finally pushed in that far, but it was as far as it would go. I'm not sure at this point if it will rub on the housing cover a little, or maybe after it breaks in a little it will seat in there a little more.
Has anyone run into this?
Yeah, I pulled the new one back out and it looked the same and was the same model #. I even stuck the old one back in and now it fit flush. I think it must have been set in a little from use as it was the original (170 hours). I'll just keep an eye on it and make sure nothing leaks and the temp stays down
