2008 Worlds Ed 22ssv speed calibration problem
The analog and digital speed'o's are off on our boat, and I am looking for some advice. From what I understand there is a way to calibrate both, but I am unfamiliar with either process.
On the analog, here's what I know--the system doesn't have a knob like the 07 Supra, and I believe that it's electronic--so, I essentially need a procedure on how to calibrate.
On the digital and perfect pass, here's what I know--PP System is the wakeboard pro 6.5 wire edition. According to the user manual, there's a calibration procedure, but the procedure is different from the screen(s) that I am able to access.
Side notes: I called the PP folks, and they said it was probably the paddle. I swam under the boat, and the paddle moved freely. So, I then cleaned and scrubbed the paddle, and I don't think that this is a problem with the cleanliness of the paddle. Also, the PP system and the analog system match; so, it's not an issue that the PP doesn't match the analog. Presently @ 26mph on the PP and analog, we are trucking along at 21mpg. So, there is about a 5mph variance between what is being shown and the speed we're going. Also, at slower speeds the variance +/- is less pronounced i.e. @ 6mph we are hitting about 5.5mph.
Any help would be greatly appreciated if anyone has seen this before. :confused:
