5 Attachment(s)
1991 Supra Comp TS6m for sale
1991 Supra Comp TS6M, 5.8L 351 Ford Windsor PCM 240hp, Power Plus 1:23:1 Transmission, 614 hrs. Dark blue/white. New speakers, New gaskets (valve covers, cylinder heads, intake, risers, manifolds) New starter, H.O. silencers, spark plugs, oil & filter (royal purple synthetic), fuel filter and Battery. Stringers and floor are solid. Has 2015 tags. Drop it in the water and go! Single axle Eagle Trailer with bearing buddy's. Available to water test. Serious Inquiries only please.
$5500.00
Maintenance as of July 2014 - 614hrs
Oil Change 10w-30 Royal Purple
Change Oil Filter
Replace fuel filter & seals
Replace Manifold, riser, cylinder head, valve cover gaskets
New Cylinder Heads (3 year warranty)
Checked Transmission for leaks/worn seals filled with Dexron III & seal stop
Replaced Spark plugs, Autolite 24 .35 gap
Replaced plug wires
Checked D cap for gap/contact
Replaced Rudder packing
Cleaned flame arrestor
Checked carb/adjustments, cleaned
Replaced cracked silencer cans, HO 3 1/2"
Checked Gauges/electrical & lights
Checked driveshaft & prop for damage & alignment
Replaced all hardware with stainless steel
New speakers
New starter
New bilge pump
New blowers & tubing
New Battery
Greased Trailer bearings
Rewired for working lights
Replaced bunks & wood all the way around, New 16oz carpet
More pics can be seen here
http://detroit.craigslist.org/okl/boa/4590210910.html
Attachment 14831Attachment 14829Attachment 14832
