My 2011 Supra Launch 242 has a height adjustable seat. I am able to raise and lower the seat, but I can not get the seat to lock in at the raised height. Anybody have any experience with this?
I have the exact same issue on my 2011 Launch 22V - the seat will seem to lock, but as soon as i start to gain speed on the lake, it unlocks and drops all the way down. I'm guessing there is some sort of spring mechanism that holds the lever in locked position. I plan on diving in to this in the next couple of weeks, but if anyone has any insight into this, I'd love to hear it.
Hey guys my 2011 21v ran into the same issue a few years back and I put up a quick how to if you can search through my posts. If you cannot locate it, I can dig for it. Let me know if you find it.
Found it:
https://forum.supraboats.com/showthr...ferrerid=16667
Thanks a million, that's perfect. I plan on attacking this problem this weekend, and this will absolutely help.
I repaired my seat today. The link provided above was extremely helpful. One thing I would add is it helps to have auto trim removal tool to remove the retaining plugs from the rubber boot around the seat base. Not only were the bolts completely out from the two arms on mine, but also the two bolts from the center supports were coming loose.
I repaired my seat yesterday. Sure enough, as soon as I moved the seat, I saw a loose bolt and nut laying on the floor. Thanks for the link and the tip on the trim removal tool, that was very helpful.
