Should Crankshaft Position Sensor (CKP) be connected on Supra 21v (2005)
Hi all,
We've had our 2005 Supra Launch 21v off the water for 6 months due to a busy period of work.
We're in West Palm so we don't winterize and it's only been stored during warm months.
Prior to storing, I filled it with zero-ethanol gas, then ran it for awhile and moved to storage (leaving it on a trickle-charger).
I just removed it from storage, attempted to start without luck. It does not get a spark.
I started to inspect the engine when I noticed...
Just below the Crank flywheel is a sensor (CKP sensor) that looks like it should be connected, but is not. I can't say whether this was ever connected in the past.
I searched all over for any wires that might connect to the sensor, I couldn't find anything. Then I searched all the forums/Google to determine whether this should be connected on my Indmar Assault 325 HP (MEFI 4-B ECU).
It seems odd there is a sensor sticking out, but nothing connected. On the other hand, I don't know how it would be possible, other than vandelism, for this to go missing -- which causes me to think that maybe there never was anything connected and I'm being paranoid.
In short ... On the 2005 Indmar Assault 325 motor, is the Crank Position Sensor used / should it be connected?
Thank you in advance for any insight!
