1989 Tsm6comp
351W
1:1.23
Right hand Prop 1" shaft
Old prop shaft broke do not have any idea what prop was on there. 3 bladeAttachment 17547
Bought new 540 13x12 RH
about 20% less speed.
What should i have bought.
Thanks for the help.
Billy
1989 Tsm6comp
351W
1:1.23
Billy
I have a '90 Conbrio and a mate has a '91 Comp and both have 14x14's on...
could always call nettle's props.
Wakemakers has a relatively good chart that I frequently default to:
https://www.wakemakers.com/supra-wak...oat-propellers
scroll to the bottom for DD boats. It recommends an Acme 422 for you - 12.5" x 15.5". In my experience with a Nautique with a 351 and 1.23 trans you'd definitely want to be in the 15ish pitch range.
Thanks for the help. It looks like the ACME 422 is the replacement.
Billy
422 should work for you. If you are commonly running with ballast or lots of people, you may consider the 1868 which is the same diameter but 14.25 pitch. Have fun, a new prop really wakes up an older boat, or really any boat that previously had an old-style prop. Just go out for a nice empty-boat WOT run and check top speed and top RPM after installing the prop.
The 422 did the trick run just like it use to only smoother.
Thanks for all the posts.
Billy
Where should i sell the 540 prop used one time.
