Has anyone had any problems with passenger seat bottom cushion where the battery compartment is located falling through or getting torn because of not enough support under the cushion ?
Make sure there are white/clear plastic pieces screwed in to the bottom of the seat. These are there to make sure the cushion does not slide around and fall through. These fit against the fiberglass and should keep it snug. This cushion should not be simply crashing in.
Thanks I guess the manufacture forgot to install the plastic pieces on the seat thanks for the help.Quote:
Originally Posted by Jon
Thanks for the info. Having the same problem with 2007 22V. I will tell dealer that there is a factory fix.
