5 Attachment(s)
2000 Supra Launch 21 - $19,000 - Houston, Texas
Updated a bit. Shes not perfect but her bones are solid, this is a great entry level wakeboard boat for any family. I'm in the Houston area.
The only reason I need to sell her is because I am moving overseas in a couple months. Boat has always been kept in locked/covered storage unit. Interior is mostly white with gray and red trim. Carpet is gray.
Asking price is $19,000 and will consider all serious offers.
Here's the Craiglist ad with more pictures:
https://houston.craigslist.org/boa/d...868392538.html
Indmar 310 Hp Engine (Not EFI) with direct drive.
Approximately 500 hours (New tachometer installed 2018 with hour meter).
Max. Capacity 10 persons and 1500 lbs.
30+ Gal Fuel tank
Original fixed rear 300 lb ballast tank.
Four blade prop 2011.
Humminbird Digital Depth Gauge - 2010
Dual batteries with manual separator switch. Replaced cranking battery 2017. Replaced stereo/deep cycle battery in 2018. Both stored on battery maintainer/trickle chargers mounted on battery box.
New universal wakeboard tower (Krypt/Reborn X-Mobe Tower) 2017
Aerial Bimini shade top, rear view mirror with clamp mount, and board racks were retained from older tower in 2011 and fit new tower.
Stereo System 2011-2013
- Sony CDX-HS70MS Marine Stereo, CD, USB line in, will work with Apple devices, does not have bluetooth
- (4) Tower speakers 6.5 Boss 250W (SJS Double Can Enclosures) with Speaker Sox covers.
- (4) Boat speakers - 6.5 Boss 250W (2 in bow, 2 midship)
- (2) Subwoofers 10 600W in single enclosures (under driver/passenger consoles)
- (2) Amps - Pyle Marine 2000W 6 channel PLMRA620 Waterproof Amp (for tower and subs)
JBL Marine 600W 4 channel MA6004 (boat speakers)
- Krypt KMA-4200 4 Band Parametric Equalizer with Mic (I only use this for a PA through the tower speakers, there are not enough channels to effectively split the tower and the boat speakers)
Boat Maintenance and Repair History:
- Purchased boat in 2010 from 2nd owner in Cameron, Texas. Replaced MDC (computer brain for gauges) in 2010.
- All major work listed below performed by Supra dealer in Houston. (Rinkers Boat World)
- Entire bottom hull resurfaced new fiberglass/gel coat, new rudder, new driveshaft support strut, maintenance free shaft packing system 2011. This repaired some minor damage done by previous owners.
- Added Hydraulic Wake Plate 2011
- New Holley throttle body/carburetor, oil pan drain kit 2015
- Fuel system clean out, drained tank, new fuel pump and fuel line, new bilge pump, new starter, new alternator and last annual maintenance June 2017
Trailer Original Boat Mate Double Axle, allow wheels, with brakes and spare tire
History:
- Replaced bunks (treated wood and marine grade carpet) in 2011.
- Added diamond plate on steps 2012
- New tires (4 + spare) June 2018
- Flushed brake system, replaced brake pads and replaced/repacked all bearings on that axle June 2018
What needs work (I can arrange to have some of these done depending on agreed price)
Need to patch 2 old bolt holes from the old tower (1/2 holes about 2 off the new tower rear mounts)
Speedo does not work (old pitot tube all removed with hull repairs), now use a basic Garmin GPS.
Needs two gauges (oil pressure and fuel level), these can be special ordered from Medallion, just got a new tachometer this year.
Does have original snap on mooring covers that needs to be repaired/replaced, they still mostly fit but have shrunk over the years so it wont snap all the way around.
Bow center cushion needs repair.
Extras that WILL be included with purchase of the boat:
Spare 3 blade prop, with case, wrench, etc.
Anchor and rope, dock tie up ropes, bumpers.
Fat Sac Ballast bags, 375 lb. Ski locker (gray) and 600 lb. (red) and various fittings. (I never got to plumb them into the fixed ballast system)
Sylvan wake/surf shaper (floating) (suction cup mount)
Other Extras up for discussion:
Various life jackets
Tow ropes
Kneeboards (2)
Wakeboards (1 Mens, 1 Ladies, 1 kids)
Tubes (1 3 Person, 1 1 person steerable)
Skis (1 adult pair, 1 kids)
I made 3 day trips to the lake last summer, ran flawlessly. Starts on the first crank (after initial warm up).Attachment 19007Attachment 19008Attachment 19009
