When shifting from forward to neutral there is a squeal that almost sounds like a something metal spinning dry with a gasket around it and squealing. Only last about 5-7 seconds but loud and happens frequently. Is there something that spins "DUH" I know the prop but when you shift is there something that secondary spins but then stops when you shift to Neutral? The noise is when first shifted into neutral. But prop on boat not turning.
