Hi All,
Hoping you can point me in the right direction. I was testing out my ballast this past weekend and found that the Right Ballast Switch isn't lighting up or turning on the pump for the ballast. However, when I turn on the right ballast from the screen it works just fine. Is there an easy solution to this problem? I feel like it probably is something in the switch itself, so is there a way to test it?
Thanks everyone. Appreciate you all!
