87 TS6M COMP Restoration
I have had request for info on my 87 TS6M COMP restoration.
Here is a link to the project on Boatdesign Forum http://www.boatdesign.net/forums/fib...ent-20668.html
I bought the COMP last year for my wife on our anniversary. "The Boss" is uncomfortable driving my speed boat due to its monster engine w/poor idle. We wanted a good light boat that was easy to tow, fun to drive and a good swim/cruising platform to use on the lakes in East Tennessee. In my younger days I was an avid skier and spent a lot of time with Supras, Correct Crafts and Mastercrafts.
This particular Comp had 675 hours (that are probably original) new unholstery and a good trailer. I bought the boat knowing it had rotten floor, was very heavy in the water and had cowl shake. I assumed she needed stringers also.
Although I am an experienced mechanic, I AM A NOVICE with this project so if some of the more experienced repair guys have better ways of doing things please chme in.
Nov 07 when we picked up the boat, you can see she sits low in the water.
I spoke with some friends in the boating business and the Supra plant manager (late 80s) and was told to do the repair correctly the deck had to be pulled.
SOOOO I pulled the deck. Then I removed trailer wheels and braced trailer to floor and hull to trailer with a few dozen 4x4s.
TOOK A LOT OF PICTURES AND MEASURMENTS!
2 Attachment(s)
Next I pulled the floor (sole) to inspect the damage. About 25% of the stringers and cross members were rotten and most all of the foam was saturated with water.
2 Attachment(s)
I used a crow bar, air chisel with blood sweat and tears to get the foam out.
The wet foam weighed over 200#s
I found the best way to cut stringers out was with a "Sawzall"
To grind out the base of the stringer and old fiberglass I used a low rpm buffer with a 40 grit sanding disc and a belt sander.
3 Attachment(s)
I cut out one stringer at a time.
Although more expensive I decided to use epoxy and biaxel fiberglass to do the repairs.
The combo is more user friendly for a novice and stronger when completed.
I bought the materials from
http://www.uscomposites.com
The inner stringers are made up of many parts and took a lot of fabricating.
I am using 3/4" Exterior AC and marine plywood.
2 Attachment(s)
WHEW!!!!!! One side done.
2 Attachment(s)
Of course use safety equipment. My shop and lungs will never be the same :(
After all that work I needed a vacation ;)
poly resin is not user friendly, i wonder what it's like using epoxy.
that is some tight work, rick.
