1989 Conbrio Oil Light and Alarm
I have an '89 Conbrio that I purchased last month. Today was very hot, and after about 30 minutes of use; the oil light and alarm came on. The pressure was between 40 to 60 psi. The light and alarm go off if the engine is turned off, it sits a little while, and then restarted.
I check the oil level and it was slightly over full.
The manual says the light and alarm represent not enough pressure.
What should the pressure be? Should I change the filter? Should I change the oil pump?
KatySupra
