I have a 2008 Sunsport 22V and the stock ballast pump has gone out. It was a Rule pump that is no longer manufactured by Rule. Anyone have a suggestion on what would be an equal or better replacement? Appreciate any help. Thank you.
Check here: http://supraboats.com/bbs/showthread.php?t=4595
This is an entire system upgrade, but it likely has some hints about what you might
want to do.
Also - have you checked with wakemakers.com?
Thanks for the input TG. I did check the link and looks like a great improvement. I'm not ready to do that much modification at this point. Perhaps the Tsunami pump would be a good straight replacement. Did also see a rule pump on wakemakers that might work.
