What type of rotation is the motor ?
My 1988 Mariah has Left Hand. Here's a sheet I made for mine, maybe it will be helpful to you too.
1988 Supra Mariah
21’, 7’11”, 2800
1988 Pleasure Craft Marine PCM
Ford 351 Windsor
240 HP, L hand rotation
Model # PLD-WR-L10
Serial # 281316
Firing order 13726548
Timing 10’ BTDC
Point Gap .018
Dwell 29-33’
Plug gap .035
Compression ?
Transmission
Borg Warner Velvet Drive
Model 10-17-00
Serial #29380
Ratio 1:1
GM ATF Dextron III 1.5 quarts
Impeller
PCM
NAPA #18-3060 $31
OIL
NAPA 40wt
Oil Filter
NAPA Gold #1515
Fuel Filter/water separator
Fram Housing
NAPA Gold 3110
Or Fram C1110P0
Plugs
Autolite #24
Points/cond/cap
PCM Tune-Up Kit #RP173024A
for Prestolite screw down caps
NAPA 18-5275 $51
Changing to electronic points use:
Mallory kit skidim.com #13212 $144
And cap #1307 $25
Carburetor
Holley E8JL 9510 CA List 50463
For parts
www.skidim.com
803-345-0996
