f/s 2 aerial tower cans with polk coaxials
2 aerial tower cans with polk 6.5 coaxials. polished chrome cans. $ 175.00 plus shipping
Don't just look good, but sound good, too, with Aerial Wakeboarding tower speakers featuring Polk Marine Certified db series speakers.
These speakers feature the single bullet pod design and bring a new level of value to your wakeboarding tower. Inside are Polk db series drivers that make these the best looking, best sounding tower speakers available.
Polk db series speakers feature:
• Dynamic Balance Polymer/Mica Composite Mineral Filled Cone is stiff yet lightweight for big sound, little distortion.
• Marine Certified Polk db Series speakers are built tough to withstand the toughest environments so they are perfect for use in boats of all types.
• 19mm Liquid-Cooled Silk/Polymer composite Dome Tweeter with Neodymium magnet for clear, detailed highs.
• Tweeter pivots, allowing you to aim it toward your listening position.
• Muscular ABS Grilles, computer optimized and based on exclusive MOMO designs.
• Durable Butyl Rubber Surround won’t fall apart under the stress of extreme temperatures, sunlight or time, for years of the great Polk sound.
• Pole Plate Heat Sink promotes better heat dissipation for superior power handling and reliability.
• Flat Spider for faster, longer excursion linear motion.
• Flexible Woven Leads sewn directly into Spider for greater reliability.
• Rock solid, acoustically inert Stamped Steel Basket finished in rustproof Gun Metal Gray.
Stainless steel mounting hardware.
Speaker specifications:
6 1/2" coaxial mid/woofer
3/4" soft dome tweeter
Nominal Impedance: 4 ohms
Frequency Response 35-22kHz
Power Handling (continuous) : 60w
Power Handling (peak): 180w
Efficiency: 92dB
Product Features
• Fits 1.725-2.5” diameter towers
• Made of quality 6061 aircraft aluminum
• Speaker wires connect through clamp -- no exposed terminals
• Pre-wired and ready for installation
• Easy to install
• 5-Year Warranty
• Finish: Polished Aluminum
