Pretty solid? I don't know anything about a lot of these materials, but it looks bullet proof. And it's got to be hundreds of pounds lighter than the original.
I painted the floors, bilge, and transom with bilge paint. Since fiberglass isn't technically water proof, I used this as a barrier coat. I added flakes to the areas that may be exposed. Once this dries, I will glue in the carpet.
http://i722.photobucket.com/albums/w...psms1uyvx0.jpg
http://i722.photobucket.com/albums/w...ps8ai0h7hu.jpg
http://i722.photobucket.com/albums/w...psaahjn3tb.jpg
I got the motor dropped in.
http://i722.photobucket.com/albums/w...pshzjkqwu2.jpg
http://i722.photobucket.com/albums/w...pskby2rfa1.jpg
Bow bulkheads/closeouts were removed. They will be replaced with a couple layers of travira and glass.
http://i722.photobucket.com/albums/w...psy3jyszai.jpg
http://i722.photobucket.com/albums/w...psxno8qofe.jpg
http://i722.photobucket.com/albums/w...pse9xnuz6i.jpg
My girlfriend helped removing the exposed wood. This will be replaced with trevira and 3/4" aquaplast where the tower mounts.
http://i722.photobucket.com/albums/w...psqccz0l5o.jpg
This is a job well done! WIsh i could have done mine all composite, you are very lucky to have those resources available!
This boat is going to be awesome, looking great. I love all of the composite work as well.
Looking good.
Here's another close up of the area that will be exposed when lifting the cushions, engine box, etc.
http://i722.photobucket.com/albums/w...psgeais80d.jpg
I laid up some trevira where the bow closeouts used to be. I'll add another layer of glass.
http://i722.photobucket.com/albums/w...psrcjpdwra.jpg
http://i722.photobucket.com/albums/w...ps4pkdggc2.jpg
I used PL adhesive to secure the 3/4" aquaplast where the tower mounts to the deck and used 3 clamps to hold it while it kicks. These will also get a layer of glass.
http://i722.photobucket.com/albums/w...psbzetlua1.jpg
I made my removable floor with 1/2" ABS plastic. Since I was using the 3/4" (plus glass) Airex foam for my floors and once I lay the carpet, it should lay flush.
http://i722.photobucket.com/albums/w...ps4tlgthic.jpg
I also used csm on the underside of the deck knuckle. I tried not to lay heavy since there isn't much room. I still have to cut/grind the excess glass.
http://i722.photobucket.com/albums/w...ps7a67qjjo.jpg
