I would think a diesel would work out ok.
I think the factory governor is set at 3500 or 4000 you will only loose around 500rpm off of the topend.
Should be easy enough to get the speed back with a higher pitch prop.
The good thing will be nearly impossible to over rev where ever the governor is set is where it will stop.
