What is your base timing??? Too far advanced timing makes hard work for the starter...
I appreciate all of the responses. Good ideas and I'll continue to look into all options. I do think there are carb issues, and it might be the cause of everything, or maybe not, but I know I need to solve the carb issues and go from there. I got the donor carb on today, but it has some minor leaks and needs tuning at least - if not more. I'm just not a carb tuner. I can do the basics, but it's so tough to troubleshoot something when you're not experienced. You never know if the test was conclusive or if you just screwed it up because you don't know. So the bottom line is that I'm taking it to someone. Throwing in the towel.
Here are the pics of the prop.
Attachment 14213
Attachment 14212
