Your front shaft seal is leaking
I am not in the process of taking the Hurth 450D out and have removed the engine mounts, swung them away from the tranny, and removed the 4 bolts holding the transmission to the bell housing. I was thinking that the tranny would slide off at this point but it is not budging. Boat is 2000 Launch DD
Any suggestions or things that I may have overlooked?
Did you support the rear end of the engine after you removed the mounts? Mine took a little wiggling and negotiating to remove.
I did support the engine, used Haugy's instructions on another thread. It just does not seem to move. I was thinking of removing bell housing, then seperating out of the boat. You were able to just remove the tranny with the 4 bolts, without removing bellhousing?
thanks for your help!
I removed the bell housing
I will do that then
Did you remove your starter?
No. 10 characters
Not sure what you mean by No. 10 charcters
The minimum response to reply is 10 characters.
