Ohhhhh, I was thinking a newer supra , Vdrive, where the cooler is post impeller. If its pre impeller then you can't use it..... my bad ....good catch cadunkle
Sounds like you're tryon to pull vacuum on the seal. This will kill it quickly. You need a water supply to the seal, tappes from the output or pressure side of the pump.
You guy are to smart . Lol , I was watching the seal as I revved it the other night and I was wondering why the damn thing was moving side to side lol , i'll get something made up this week to put it after the raw water pump, it's just hard to find one inch barbed ends that are in a T , to 3/8 barbed
Remember my post? It takes some work but your best bet is to find a brass T fitting that has the O.D. you need and then open up the I.D. to allow better flow and install it right after/on top of the raw water pump as the line runs up to the T-stat housing. Today is my "Monday" starting a five day block of days so I won't be able to get a picture of my set up until Sunday at the earliest.
https://uploads.tapatalk-cdn.com/201...39b3c520b9.jpg
What kind of hose are y'all using ? I have some hard plastic kind a like pex but I'm kind of thinking of using just soft rubber hose
https://uploads.tapatalk-cdn.com/201...7e5281ae82.jpg
