Another tip, since you mentioned the impeller...
I take the impeller out when I winterize at the end of the season. That way it doesn't take a "set", with some of the blades being flattened while others are extended for several months. I then reinstall it when prepping for the new season of fun. It's not necessary, but is does extend the life of the impeller a bit.
The only bearing that needs grease servicing is the rudder post. Nothing on the V-drive or Tranny. If you have replaced the steering cable, some aftermarket cables have a grease fitting. The original does not.
Awesome thank you very much
check your motor mount bushings for wear and your drive shaft alignment......there are good how to's on the moomba board
