3 wire. It has built in float switch I don't think the Rule you have does. Which is probably the difference in wiring.
Yep must be because I found out the Rue 10 does not have a float, you have to turn it on for it to pump water.
So I took the pump apart to clean and see if the pump was bad, turns out when I connect to 12v power it runs just fine. So now I guess its something in the switch or wiring because the fuse is good as far as I can tell but the light on the console does not light up red when you toggle it.
