Jetlink I bought a PSS for my 87 Supra Comp Ts6m, just wondering how did you manage to fed the water for cooling. Do you have pictures?
Pull it from after the impeller pump and before the tstat distribution housing. Slice a fitting between or if the tranny cooler is after the impeller pump there may be a fitting on it
It is tapped and pulling right after the raw water pump prior to the thermostat housing. I do not have any pictures of the setup handy and I will not see the boat again until late April. I ended up sourcing a fitting instead of using the one that came with the kit as I was pulling from a larger diameter hose than the kit intended.
