Not sure if I have any pics on my work PC, none on my phone.
Plumbed like this:
One reversible pump was plumbed to this Bosworth Wye Valve. I had it mounted in the floor hatch - easy to access.
One output went to the center ballast bag.
One output went to the bow bag.
You could direct what bag to fill or drain by twisting the handle.
Both the center and bow bags had vent lines that were connected, via a Y-fitting, out the side of the boat. I think I had check valves too, so the water did not back into the other bag.
On the second year for the bow bag, I added another line to fill/empty. Since the bow bag is an upside down "V" shape and I originally had 1 fill/empty line, one side would drain and the other would hold water. So from the one output on the Bosworth Valve, there was some hose and a Y-fitting (equal lengths) to the bow bag fittings.
https://uploads.tapatalk-cdn.com/202...2d4c678971.jpg
