What boat did this come from?
The mechanism isn't attached to the plywood at all. The plywood is attached to the back of the fiberglass. If I could get the plywood out of there I might be able to snake this control out finally. But I'm betting that wood is glued to the fiberglass and not going to part easily.
Quote:
Originally Posted by
DAFF
I can see the set screw on the first pic. Removing it is the first step into this riddle. Remember things are always built in this era to come apart without much prying or effort.
Attachment 12436
Removed set screw, got me to this point.
Michael, I'll check it out and thanks for digging.
Daff, I totally understand what you're saying but I have a sneaky suspicion that this isn't the original morse control to this boat. And looking at the opening that I have to try and get this out of leads me to believe that they had to pry it in there which is easier than having to pry it out.
I had both the transmission linkage and the throttle linkage removed as well as plenty of slack in the routing of the control cables. I'm truly and utterly stumped on this one because as I see it, I have everything loose and undone and it is still stubborn and not wanting to budge.
