I would be very sure you get all the bits out of all the cooling passages. My father had to replace the heads on his after the impeller shredded and the shop did not get all of it out of the heads and the boat then overheated and cracked both heads. I took out the freeze plugs and ran water through the thermostat housing to flush all of the bits from my motor when my boat shredded a impeller.
