Finally got the new coupling. I am pretty sure this is brand new, as nobody in the country had one, but here it is...
http://i1082.photobucket.com/albums/...t/DSC02799.jpg
This pic is the new coupling on the left, with the one every other Supra uses on the right. Bottom line...no contest! The newer one is heftier and uses nylon bushings that remove all play. You can see the original just uses a strap to hold the bolt that goes through the tiller arm. Lame.
http://i1082.photobucket.com/albums/...t/DSC02803.jpg
Here, the bolt hole closest in the pic is where the steering flex cable attaches. The larger bolt is the one that goes through the tiller and bolts tightly to the arm. I honestly can't believe we have been using that chinsy coupling all these years.
http://i1082.photobucket.com/albums/...t/DSC02804.jpg
So, the play in my steering is less than half what it was at the wheel. This is an upgrade I highly recommend!
How much play does part E have in your system? I am finding mine not only pivots side to side as it should but also transversely to the intended direction.
Mine swings and pivots,but has no "play" that I can detect.
