Originally Posted by
jasun
I vote for a timing issue. Did you just replace the Dist Cap or the whole dist? When I bought my salt it would start but then wouldn't run unless it idled at 1500 rpm. thought it was the carb and I changed out the Holley for an Edelbrock but still didn't fix it. Ended up one of the springs on the dist was bad or broke... was not advancing as it should have. replaced the whole distributor with a:
PNX-D200800
Distributor, Marine, Plug and Play, Magnetic, Mechanical Advance, Black Cap, Chevy, Big/Small Block, Each
(Mfr. #: D200800)
Ran like a champ after that.
If you can take your distributor apart check for any broken or bad springs.
What is your timing set at?
