I was thinking the same thing and I'm only 1000 miles away. That would be one hell of a haul for you.
Is the boat still available?
Boat has been sold. Thanks everyone for your interest.
Way to go Mr. Hunter!!!
Well trailer pulled great at 70 mph the 500 miles home. I will see if she runs today
Did the ferns make it ok ?
ferns are ok but probably wont make it through the GA winter.
Got it home hooked up a battery and fuel source and she started right up . Everything looked ok so I pulled the engine and trans . I took the engine down to a long block cleaned and painted each part. removed all the freeze plugs and cleaned out the cooling system. There was a ton of rust and scale plugging up the block , heads and manifolds. This is the reason I recommend storing engines with antifreeze .
