also consider dropping the trailer in far to wet the bunks and then pull it up to the point that i mentioned or continue to do what is working for you. when the bunks are wet you will be able to slide on a little better.... simple fact to remember is if you are on your bunks (front and back) you won't hit the prop guard.
Good luck and sounds like you are on the right track....
