It sounds like the damper plate may be broken it is the connection between the engine flywheel and the transmission input shaft kinda like a clutch on a car . If the damper is broken its a easy replacement. Skidim has them.
That's already been replaced.
08-07-2020, 05:30 AM
michael hunter
If the input shaft on the trans is spinning and the output is not check the drive shaft cuppler if its ok the trans has an internal problem . Its a 1 to 1 gear ratio.
