Hopefully that does the trick. If, not you will need to get more in depth on the troubleshooting. You really need to check fuel pressure at the schrader valve located on the high pressure fuel line, but you will need a gauge. It could possibly be the TPS, MAP sensor, ignition control module etc. I bought a scanner for mine this year to check for codes and view live data while its running. $500.00 bucks thru Rinda Technologies. They make an inexpensive code reader also for $60.00. You will need to get the list of codes off the net to see what may be stored in the computer. I keep cars,boats, motorcycles a long time, so it was worth it to me to buy the scanner. One trip to the dealer would be a whole lot more than that.
You may also have a really crappy batch of gas that needs to be burned out.
