Ohhh, ok. So I called around and found marine grade 3/4 in. plywood for $122 for a 4'x8' sheet. I really only planned on using the marine for reinforcing the transom to add support to the teak deck. The deck seems to strain the transom when you put weight on it.
Plan: Remove the existing foam for about 24 inches away from the transom,
clean everything profusely, fiberglass/epoxy the rear section and
transom, I'm planning on putting it on real thick, then cutting my
marine grade wood almost the same size as the transom and fiberglsng
it in, then rebolting my teak deck.
Good idea OR bad idea?
