Can you tell me any more about how it is set up? Does it have a vent/overflow line that exits the hull so you can tell when it is full? Do you have a sac in the rear ski locker too and are the connected? What type of pump do you use? I would love to see a pic of how good of a fit it is for the rear bench seat in the SunSport.
Ditto, what Mikey said! do you also happen to know how many lbs of water it holds? I'd love to have my ski locker back for storage.
I want to use BOTH spaces hehehe!
Hey sorry for the delay here, haven't been on the forum for a while, too busy working so if the sun ever comes out here!!!!!! I can use my boat! Yes, it does have an overflow so I can see if its full, it is a 55 gallon tank, so about 460 lbs or so, it is also connected to the front ballast, and filled with a seperate pump. About that ski locker, filled with a 370! but I still put some stuff in there when it's not full. The 370 and the 750 I run are both soft and not hooked up to my built in pump, which sorry Mikey I actually know nothing about, except I hit two switches one to fill the bow and one to fill the hard tank. The others I fill manually with a tsunami pump. By the way Mikey, I'm getting my surf wave dialed!! just following ur example.
