I put the ball valve onto the stock hose. Then used the 3/8 fuel hose to span the distance to the pump. The diaphram pump linked above may be a better thing. It accepts threaded fittings. You then could use hydraulic hose. This would leave no change that a hose clamp wasnt tight enough.
