If that's a PCV you're running (which I recommend, helps to keep the crankcase clean), you should run a breather on the other side. A good sealing engine (rings) will pull vacuum out the opposite valve cover from the PCV. You should have this connected to open air so you get fresh air flowing through the crankcase.
