The old prop had a couple of dings on it. I have not had a vibration until the this past Sunday.
I just order the windy blinks. Hopefully that will something if there is something going on engine related.
I had a similar bog in my 2008 a few years ago with only about 200 hours on it. It was literally dirty/corroded contacts in the cap and rotor. I took it off and cleaned them up with a green scotch pad, and it fixed the problem. I replaced my plugs too, but that was probably not necessary and they were kind of pricey. I didn’t have a vibration though. It was very hit and miss too, like you are describing, so was hard to duplicate. But, it might be worth checking out for a cheap/free fix.
updated..... replaced the ignition coil and it solved the bogging i believe. Checked my prop again a little closer this time and found 2 fines bent. I coundnt tell until i checked it moving......prop was 3 weeks old.
I took the boat out this past Tuesday. It ran perfectly. New prop and new ignition coil. No more bogging(ignition coil) and more vibration(new prop).
